99 4.0 attached to a 4r55e swap into a 95 2.3 with a m50d and ttb
my 95 2.3 has a m50d. the transfer case has a yoke because of the double cardan joint. the 4.0 is bolted to a 4r55e, and the 99 has ifs so the transfer case has a flange. will the transfer case on the m50d bolt right to the 4r55e. are the transmission out put shafts the same size also?
