jlbutler
- Dec 19, 2015
99 2wd explorer rims on a 93 2wd ranger
I can't find anyone else having this issue...maybe I'm losing my mind....
Same bolt pattern on both the rims, but the 93 2wd hubs are smaller, leaving a gap around the hub to rim. The ranger had 225 70R14 deer hoof rims and the explorers are 235 75R15 tear drop type. It was said in the tire info thread that 235 75R15 could fit and they do fit fine, except the rim and hub part. I've done research into the hub-centric vs lug-centric debate, and I don't want to start another thread on that if I can help it
I vaguely understand the older 2wd Rangers had smaller hubs, but is it only those 2wd? As in, the new 2wd wheels fit the new and old 4x4 hubs?
If I want to use the Exploder rims, what options do I have? I need to replace the bearings, is it possible to replace my 93 hubs with the newer, larger hubs?
