98 taurus engine into a 2000 taurus
black_demon69
AZ
is it possible to put a 3.0l from a 98 taurus into a 2000 taurus?
i think it is but just need to confirm before i buy parts and supplies for the swap..
and yes i know the intake and what not would also have to be swapped...
Trick question :)
1998 was 3rd generation Taurus so would would have a 3.0l OHV Vulcan engine, same as Rangers had.
2000 was 4th generation Taurus, and had TWO 3.0l options
3.0l OHV Vulcan
3.0l DOHC Duratec
These engines are not interchangeable, totally different designs and transmission bolt patterns.
So first you need to ID what engine is in the 2000 Taurus now, if it is a 3.0l OHV Vulcan then yes, the 1998 engine will work.
Taurus engine VIN codes here if needed: http://www.ford-taurus.org/taurusinfo/Engine/VIN8.php
FFV = Flex Fuel Vehicle
FFV and Gas only engines can be swap as long as you swap injectors(intakes), FFV uses larger injectors, needed for the lower powered fuel, FFV computer expects these larger injectors regardless of the fuel used, Non-FFV computer would throw codes on some occasions using FFV injectors
it is currently vulcan ohv flex fuel; engine out of 98 is vulcan ohv non flex fuel
I used to do stuff like this with bugs. Wiring was a 1/2 dozen push ons and one that needed a screw driver. :D
