98+ sas steering box question
funinthemud
Solid Axle Swap
Vienna, WV
whats everybody using and how do you like it. i've seen some toyota boxes and eb, but are there any other options? thats were i'm at on my build and not finding a lot of info on it
toyota box off an ifs truck. It fits nicely, biggest pain about it is making the steering shaft. But It does pretty well. Still need to add some plating and sleeves to my frame cause right now its just attached by holes in the frame. Steers a lot better to the right than to the left but that also might be my fault.
thanks are there any certain years, or models that i should look for or just any ifs?
The 4 wheel drive pickups and 4runners from 87 to 94. Any year should do as long as it has the ifs. Make sure to get the steering shaft as well. When I did mine I took the whole steering column out of the yota just to make sure I had enough stuff to make my steering shaft.
