ambrose
- Oct 17, 2008
- Automatic
what the hell...
so i took off the cover for the pass side rear speaker, cut that connector thing and spliced the wires, twisted them with the speaker's wires, and all is good.
i open the driver side, and this time there isnt a wire that comes to an end with a connector. i see two wires that run laterally and seem to run into insulation which is between the 2 speakers. they both are connected to one beefy bundle of wires that run up the cab's corner. here's a pic maybe it helps. that big square at the top is the rear cab window, the two squares are the speaker openings, the spray stuff is the insulation.
anyways, i can't find what the hell to wire my speaker into... i ran my hand all through there and couldnt find anything. it's dark outside so maybe that makes a diff, but for the other side the wires were nicely taped to the cab!!
