dougs55
- Apr 1, 2014
- 1998 Ford Range
- Automatic
Ok, I posted this same info in another spot but maybe this forum is better to get a quick response since there are more folks looking.
I am at my wits end with my Ranger, over the last 90 days I have replaced or checked everything below and now it has a high idle, rough cold start and check engine light on ---again! Anyone got any ideas since I have virtually replaced everything that I can think of?
Mass Air Flow Sensor
O2 Sensors (All Three) Downstream twice
Electronic Computer Module (Mounted in Firewall)
EGR Differential Pressure Switch
Fuel Pressure Checked – 62 PSI
Right Crash Sensor Module replaced
Changed Vacuum hoses on EGR Valve
Replaced Fuel Filter – Twice
Checked for vacuum leaks and replaced the intake upper intake gaskets
Verified EGR valve is free and working
Replaced heater hose valve
Gas Cap
Cleaned the throttle body with TBC
Replaced Throttle Position Sensor
Gas Cap
