98 ranger v8 swap help
gary2666
i need more specific then the technician library, i have a 98 ford ranger v6 3.0 2wd i can get a 89 5.0 ho motor furl injected for $200 with 89k origional miles i want to know if it possible to do it to a 98 ford ranger and what else i would need. the trans wire harness and computers? help me out please also i can an auto trans with the motor but i rather keep it a stick
your link didnt help=(
so your saying i should find a whole donor car instead i dont have much money so i figure i get the parts little by little when i can i have junk yards near me and my uncle is a manager and a very good mechanic at a salvage yard so what do you guys think
You don't need the whole car but it's usually cheaper that way. You will need the Explorer wiring harness and computer and front dress to make everythig much easier. The Explorer has the better intake manifolds and throttle body. You could start using that Mustang motor and buy the Explorer parts to switch over to the matching Explorer/Ranger systems, that's what Stranger meant by it costing more and being a headache. Buying the parts bit by bit can cost you triple the cost of the motor.
Dave
That FURL injection will really make it go LOL! j/k. If you want a manual tranny go with a T5 from a Stang' or a V8 T-bird, and if you dont want to mess with all of that wiring go the carburated route.
its almost plug and play.i think 3 wire difference if i remember right.alt wire,ampmeter,and ground. easiest wiring easier than carb
the v8 swap is much easier in the 98 and newer. The front suspension is the same as the explorer, etc. I have an explorer wiring harness, computer,coil packs, oil pan, engine mounts.... shoot me an email if you need anything. Saleenlimited@yahoo.com
