98 ranger ac not working
jbrown98604
I have a 98 ford ranger and the ac is not working. I jumped the pressure switch, it did not make a difference. so I ran a hot wire and ground directly to the compressor and it blows nice cold air?
probably a bad relay
It took some work but I found it the ac relay is located near the power distribution box on the radiator side. so If anyone has no power to the pressure switches or compressor check this relay you can use a horn or wiper relay to confirm problem.:yahoo:
