- Feb 28, 2001
- Dayton
- State - Country
- OR - USA
- Drive
- 4WD
- 2.3 (4 Cylinder)
- Total Lift
- 6
- Tire Size
- 35"
The front driveline with the 4406 is conventional with U joints on either end so has a slip joint in the middle, there was just enough room in the slip joint to compress the shaft to get it out of the yoke on the front diff after the straps were off. Most drivelines aren't rated for a whole lot of extension on that slip joint so I imagine there's 1" of room for further extension which should account for the differential moving down say 4" like a lift kit would do.Ok, you've got me confused there. Fully compressed and has 1" extension left?
Just not seeing how it can be fully compressed and only have 1" of extension available. Did you use the correct terms there? Of course, I'm also not looking at a 4.6 driveshaft either, so maybe it would make sense then.
