98 ranger 2wd lift question
then ull need new shocks yes. larger ones.
the 4WD ones will work
98 and up only.
either 4wd spec shocks or taller shocks, like rancho or something alike
ok well those are both 98+ One set says 0-2" lift and the other set says 0" lift. which do i need?
the 0 lift ones would work.
since ur going to stock 4wd height. it should be like a 4wd without extra lift.
Where did you get your spring spacers, I'm trying to lift the front of a 2000 2WD w/coil springs and can't find spacers.
