Hi everyone. I have a 98 Ranger 2.5L, 350,000 KM .Was driving ,started to bog down then stopped. Will crank ok, sometimes will start and run for a second then quits. I get no codes. Fuel pump relay seems ok KOEO can hear pump pressure build up for a couple of seconds. Last time this happened I was out of gas cause fuel gauge was lousy. I put in more fuel this time, added gas dry, but no start. Last year fuel pump ,IAC,TPS,fuel filter was replaced. Truck has been running fine until now. I am going out to replace fuel filter and check fuel pressure but was wondering if anyone can suggest any other things to check. Thank you.
