98 Mazda B4000 4x4 trans replacement
juice90
Might have asked this before, but can't find it if I did.
98 mazda B4000 4x4. trans toast.5r55e auto. Found a used one from a 2002 explorer 2 door sport. I am aware that there is an extra speed sensor on it, that isn't required, but Wondering if there is a difference between the trans used in the 2 door and the 4 door Explorers? Seem to recall seeing that maybe there was.
Otherwise, this trans should work, no?
Yes, the transmissions used in the 99-01 Explorers and the 02 Explorer Sport is different from the trans used in the 02+ four door "Big body" Explorers.
One is a 5R55E, the other is a 5R55S or W. The internals of the four versions of the 5R55 are very similar, but there are only a few parts that actually interchange between any of them. The electronics are all quite different.
https://www.thetransmissionshop.com/fords-four-versions-of-5r55/
http://www.explorerforum.com/forums...e-with-the-various-5r55-transmissions.241131/
