98 Ford Ranger Front Axle Problems
jdsegura02
Atascadero, ca
Hello, my name is Danny and I own a 98 Ford Ranger XLT 3.0 4x4. For the past three years I've been having problems with the front axles well its more like the the right front axle CV boot I believe. I've had to replace it three times already and I don't know why. The rubber boot starts to crack and then eventually breaks opens and the grease inside just sprays all under my wheel well. I don't why or what the problem is, so I was wondering if anybody know why its doing this or if there's anything different I can do or if I can install an aftermarket front end or what? I just need some help to fix this PLEASE!!!!
Thank you
Welcome Danny. I have a couple of questions for you about your issue. Which boot is failing on you; the one up on the axle or down behind the wheel? How is it failing? Is it a tear, crack, etc.? How often are they failing you? Is it driver side or passenger (I know you said right, but right is different to some people)?
The most common one I've seen fail is the driver side lower joint because it's on more of a bind. Assuming it is the lower joint, here are a couple possible causes: If the bearing is bad it can cause that joint and boot to fail. If you don't have the nut on the end tightened to proper torque specs it can cause the issue as well.
When you are buying a CV joint, what are you buying? Used, Rebuilt, or New? It would be my suggestion that you buy new. Napa sells them new as does Autozone under the Duralast Gold brand.
Hope this helps
Its the passenger side boot and its the boot right next to the wheel/brake drum/tire. The boot cracks like when rubber dries out its starts cracking well like that. Like I said I've had to replace then three times already. The first to I replaced them like 6 to 8 months later and the last one has last colse to a year now but its starting to crack already. As for the CV joint I have my mechanic buy new all the time.
Also I'm wondering if there's and upgrade or aftermarket type front end to where I don't have to deal with this.
