Rosscoinc
- Nov 26, 2013
- Automatic
Hello,
I have a 1998 Ranger 4.0 XLT 4x4 and I am completely baffled by the following:
What I have done or what is newly installed -
New crate engine with 10,000 miles
fuel pump
fuel filter x 2
MAF 2 years old, just cleaned
all new relays
new coolant sensor
new throttle sensor
new K&N filter
tune up (plugs, wires) at engine install
visual inspection for vacuum leaks. 1 found and it runs worse when plugged.
What is happening:
Just before leaving for hunting the truck stalled out and would not start seeming like it was getting no fuel. It would start after pumping furiously on the throttle for a minute or two. I replaced the fuel pump and filter and it ran fine for 2 days then started doing the same thing. Very hard to start whether cold or hot. When I am pressing on the accelerator it will do fine but when it idles it will go up to 2000 rpm (roughly) then down then up, down, up down etc. When it finally settles down it goes to 500 rpm or so and goes up and down a little then it will eventually stall. I cleaned the MAF and then it got REALLY bad. After changing all the relays it seems a little better except that now when pressing on the throttle it dogs out and almost stalls. I have to gentle pump the throttle to get any rpm's. It does start ok now after it warms a little bit but seems like no fuel when first starting cold.
I am at a loss at this point. Do I spend the money on a new MAF? Get a vacuum system test? Anything else to try? Please help as I do not know what to try next. Coil pack maybe?
Thanks,
Ross.
fuel pump
fuel filter x 2
all new relays
new coolant sensor
new throttle sensor
new K&N filter
What is happening:
Thanks,
Ross.
