98' 3.0 to 03'
DavePolyakov
Bellingham, Washington
I got a 93 3.0 motor to replace the 98 that blew up. There are some differences between the two correct? What needs to be changed over between the two? I know the intake manifold is different and I believe the valve covers, I'm not sure if everything will go together with the newer stuff or not. Any help greatly appreciated, thanks.
Bump, has anyone done this swap?
This might help
Biggest issue might be the ECU. 3.0 may bolt and can be plugged on differences but the computer and connections do have differences which can make the swap your doing a headache.
Ford's might be interchangeable but that's usually only for a generation or so. You're talking about a good 5 years man.
