bigdan002001
Okay, I recently purchased this ranger and have gone thru numerous problems and trying to fix things as they come. I just fixed the major vacuum leak from the intake to vacuum ball canister on the inner fender with a new vacuum line. Now the controls work inside like they should...it changes from defrost to vents to floor all as it should. My blower resister needs replaced cause I only have high speed on my blower fan...gonna fix that tonight. But my a/c compressor never kicks on at all. So I tested the low pressure port and I am getting power there, but no power is coming to the high pressure switch or the compressor to kick it on. So I unplugged the compressor and ran a hot and ground wires from my battery over to the terminals and off she went...let if run for like 15 min. but to my dismay...still warm air coming out the vents...so I can only assume that it is either empty of coolant or someone has overfilled it? Which leads me to my next question...I took the cap off the low pressure side switch (where you would add the new refrigerant) and there was a lot of green gue which I again can assume is R-134A coolant? Why would coolant be leaking back up thru the low pressure port after I ran the compressor...never showed up before when compressor wasn't running? Any help would be appreciated.
Thanks,
BigDan
Thanks,
BigDan
