moonbeam
After getting new engine in I found the CMP connector is different from the old one. I need advice on how to correct this problem. I removed unit from the old engine but need to make sure what I'm doing before I go any further. Also, what's the best way to get the bolt that holds the unit in place out while in truck. I haven't been able to get a 10mm wrench on the bolt. Is there a special tool? If you have any pictures that wold be great too!
