97 ranger 2" lift shock question
DetroitJeff
Detroit
I have a 97 2wd 2.3 5 speed that i have put the 2 inch poly coil spacers in. I need to know what shocks I should look for at the parts store to work with the added 2 inchs. Thanks.
Stock shocks will work just fine.
Stock shocks worked fine for my 92 with poly spacers. If you wanted i think 4wd ones might be longer
I think the 4wd shocks are the same actually. I run Rancho RS9000x adjustable shocks with my leveling kit. they are designed for a 2.5" lift.
