jsob
- May 3, 2015
So I replaced my plugs and wires, oil and oil filter. fired my ranger (after correcting my fireing order
) up all fine. tinkered with my idle cause it seemed pretty low and still to be a little choppy.. Then read on here that i should unplug the battery to rest the computer. Well problem is, my battery cables nuts are rounded, so not wanting to replace them at this moment, removed some relays and fuses to "disconnect" the computer from power.. Well inspecting the cable i noticed the body ground from the battery to the body was broken off.. I put all the fuses and relays back, started it up fine.. okay? seemed off, so i redid the ground wire... Now the truck wont start without being jumped.. runs fun after its jumped, just when you try to start it just clicks like a dead battery and dies out slowly.. fires up when jumped without a problem and stays running.. Thought maybe i killed the battery somehow? let it run for about 20 min turned it off, BAM doesnt start...
Any ideas on exactly WHAT i did? I asked a few mechanical friends they all seem a little "stumped" ("don't work on fords, or know much about the wireing.. sorry")
Just got this truck about 2 weeks ago, it's been nothing but issues.. about 200$ for a hack job exhaust because nowheres around here had stock fit that wouldnt take a week to get here, has a bad body mount.. Gas splashes out from the top of the tank? unsure where cant see... Thank god i got it cheap...
1997 Ford ranger 4X2 5 speed 2.3L
