'97 F-150 Available engines?
Twizzler09
Morrison, IL
Just wondering if anyone knows what motors were available in the older '97 F-150? Been eye-balling one I want to buy but its just the base XL package and I can't remember if you could get the V8s in the XL or if Ford would make you step up to the next trim package to get it.
I think you could get anything, 5.4's are not as common in '97's as the '98+ trucks though.
Options would be 4.2L V6, 4.6 V8 and 5.4 V8.
Interesting you mention that. Do you know if the 5.4 is a late 1997 addition? I was looking up fluid type for my differential yesterday, and I noticed my manual only has specs for the 4.2 and 4.6 motors - no 5.4 info listed. My truck was manufactured in 6/96, so it's one of the first 97's made.
Actually I had that typed at first but since I wasn't for sure that was the case I changed it. Hard to tell if it was limited availablity or just a late entry, but you pretty much solved that. :icon_thumby:
I couldn't figure out if the 5.4 was part of the '97 model year or not either, wikipedia articles suggest that the 5.4 was available in '97 but I can't seem to find any examples of it, and we all know how reliable wikipedia can be...
Anywho, going to go and look at it close-up tonight. Even if it has the 4.2, hell thats good enough for me. The Ranger decided to implode another slave cylinder last week, and I'm getting tired of the disassembly/fix/reassembly cycle every six or seven months. This time it nearly got me injured, stupid thing went out with no warning while I was driving. Just can't seem to get a handle on whats causing it to do that, so its getting gutted.
Well, here's maybe another twist I thought of. My Father-in-Law had the F250 version (same body, etc.) with the 5.4 engine. I don't recall the month, but I know it was an earlier truck. I almost wonder if it started as an F250 only motor, and then they moved it into the F150. I also know for sure there were F150's with the 5.4 in 97 because I test drove one.
Since we're on the topic of the early modulars, didn't they have a problem with spitting spark plugs out of the heads?
Dunno about that, but they had a serious problem with spark plugs
seizing to the head, and exhaust manifolds rusting out.
Sent from my HTC Mecha using Tapatalk 2
Yes, but the 4.6 wasn't as bad as the 5.4 was. I read recently that it was believed that there weren't enough threads on the original spark plugs. The newer plugs that have more threads. Here's a comparison.
This is what the factory plug looked like (these are no longer made)
This is the new style:
I just recently got a 2004 f-150 with the 5.4. I got it cheap because of motor problems. In my research the early model 5.4's, up to '03/04 had a bad head design in that there wasn't enough threads in the head to hold the spark-plugs in. in '04 they redesigned the head with more threads for the spark-plugs. And I guess also redesigned the spark-plugs too as your pics show.
My problem is with the cam phasers. If the motor doesn't have too low of oil pressure I may be able to get the phasers fixed for about 2500.00. otherwise it's recomended to replace the motor....6000.00 and up.
But I only paid 1000.
Richard
04+ 3v mods have a really long reach spark plug, the extended part was crimped onto the nut part. Carbon would form between the extended part and the head and stick them in there and they would twist off the nut. The updated plug is all one piece.
The exhaust studs get that weird steel vs aluminum corrosion and combined with the different expansion rates of cast iron and aluminum they break and cause exhaust leaks. Not really common for the manifold itself to break... they do but to a certain degree any cast iron manifold can.
The 97-03 5.4's catch a lot of flack about plugs blowing out, I have 94k on my '02 and knocking on wood I haven't had a problem. It stems from a lack of threads in the cylinder head, nothing to do with the plug. Later heads have more threads which is probably what spurred the plug with more threads.
Usually it is the phasers that go out of the 04+ 5.4's, a couple grand if you don't want to do it yourself and an all around big PITA and it is all fixed up. :icon_thumby:
Personally I would rather worry about the plugs blowing out (which IMO the internet has blown way out of proportion) than both the plugs breaking off at service AND the cam phasers screwing up. I have resigned myself from buying a new truck until the 5.0's prove themselves. In theory they have both improved (and much simplified) phasers and the one piece plug... but I want to see how they stand the test of time and for them to age into my price range. :D
I found my "Ford F-150 Pickup 1997-2005" book and looked up when the 5.4 became available, it says fall of '96.
Good info. Was this the PI heads that received the extra threads?
Sent while I should be doing something else
No, it happend in '03 ('04 was the last year of the 2v in the Superduty and I think they are still going in Econolines)
Well, I won't have to worry about plug issues or anything of that sort. I suspected that the truck had the 4.2L V6 in it, and as it turns out, it does. I was a little iffy on that, but I drove it around for a half hour and found that the 4.2L is a bit heartier than I thought it was, so no complaints there. Don't know much about these Essex V6's but I can't recall anything being too wonky about them.
The Essex engines are powerful, but they have their issues.
The 3.8L warps head.
The 4.2L grenades the bottom end.
