97 2.3 ranger, motor help
Belleview FL
i have a 97 ranger w/ the 2.3, 5 speed. i believe the headgasket is blown, but the oil is not mixing w/ water, well not enough that i can notice. it runs rough at idle, and runs rough till about 2 grand, then runs fine.
It all started when i pulled a buddy out, broke a motor mount which broke the radiator hose, and it overheated. but not to bad.
Any ideas what it could be? im a new member to TRS and love the site, thanks in advance
If you think the head gasket is blown do a compression test.Is it blowing any white sweet smelling smoke out of the exhaust? if so another sign that it is bad.If you pull the plugs you should be able to tell if you are burning anti-freeze.The plug(s) will be clean.
yes it was blowing out white smoke, i put a new head gasket in and it runs so much better. even though it was a pain to put a new gasket in.
But now however, i have a rough idle, i put new plugs and wires in as well. this rough idle has been going on ever since i blew the head gasket, could a burnt valve do that? any ideas? thanks
I would verify that I had no vacuum leaks,clean IAC,Check codes if any.Does it smooth out above idle?If so probably not a burned valve.
