Fraser
97 2.3 Miss/ misfire
bought the truck a month ago, started out w/ a bank lean code [loose down pipe at the manifold, fixed] and then threw a 1443 code and it came to be a hose on my evap canister being wasted and had came off of the canister. did a full tune up b/c it kinda ran on the crappier side and had some issues starting. runs pretty good now, but if i shift into 3rd early and lug the motor down, or lug it down in 5th speeding up, it misses noticeably. It was on the bad side before i fixed the codes and changed the plugs and stuff but its still hanging around. It is not throwing a code for any sort of misfire, so i was wondering if there is any common issues or things i should look into. Tested the mass air flow and the tps and they check out good
