96 TTB questions.
shane96ranger
Utah
Well, I've got some front end work to do. I figure I may as well do "at least" the leveling kit while I'm in there. My truck does the classic nose dive from the factory. My question are:
How high can I raise the front without messing with relocating the radius arms?
Can I put the 2 inch spacers as well as 2 inch lift springs?
If I go 4 in the front, I only need 2 in the back, right?
can only go a max of 2 in the front before you need drop brackets...2 inch in the front will level it out
and whatever you do dont go with any sort of poly front spacers, they wont last long
Thank you! I think I'm just going to level it then and go with 33's next time I need tires. And thank you very much for the advice, I was contemplating whether I should go with aluminum or poly urethane. I was told the aluminum spacers squeak. Is this true?
never heard any issues will the metal ones...i made mine myself with a peice of 2 inch tube and a 1/4 plate...works great with no complaints
with 33's youll have to do some trimming up front
I used Skyjacker leveling springs and have 33 on my truck have yet to do any trimming....
It does a little when I turn hard but that is it!!
