96xltV6
hey guys. heres a little background on this ranger. I bought it from a used stealership, big mistake. the dealership kept it for 2 months trying to get it to pass emissions so they could sell it to me. i got it for cheap cuz of that.
it developed a misfire. i had so many things replaced..cat converter, iac, maf, tps, coil pack, wires, plugs, and none of it fixed the misfire.
a couple weeks ago i took my plastic intake manifold plenum off, and the misfiring cylinders fuel injector plug was on upside down. i flipped it around and put it on correctly, threw everything back together, and it doesn't misfire anymore.
Now, there is a hissing noise that i can hear from inside the cab. My idle sits at 2500RPM idling.
this hissing noise did not exist before i took the plenum off. I've checked all the vacuums i can find, and i even have a haynes manual, but i can't find it. It can best be heard when i turn the engine off, cuz it hisses for about 2 seconds after the engine is off. i've tried the unlit propane torch, water, wd40, brake cleaner trick, spraying it near the engine, and the idle doesn't change. every vacuum hose is on tight.
a couple days ago i took my plenum off and the gaskets look fine, and i orange rtv'd everything. it didn't make a difference. i still hear the hissing noise.
How do i diagnose this hissing noise? I can't feel it because of the wind that my fan creates.
I've been trying to fix this truck since march, 2007.
