MathewSK01
Last week the a/c clutch needed to be replaced because the bearing was grinding. After I put the new clutch on, the front plate spins slowly and grinds a little bit regardless of whether the a/c is turned on and it won't blow cold air when it is on. The old clutch had a thin washer in between the front plate and the pulley which I didn't put on the new one. I thought that might be the problem but I put it in and the front plate doesn't spin at all, even when I turn on the a/c.
