fighterpilot
- Jan 5, 2009
- Automatic
96 Ranger 4.0L - Key will not turn off engine (NOW SOLVED!!!)
94 Ranger 4x4, 4.0L Supercab w/ 5 speed, 204xxx miles.
Issue just started overnite. Changed oil last nite, started it up w/o problems and parked it in the steet. Came out this morning and battery was dead. Put an all day charge on it with negative cable off. Hooked cable back up with key off and noticed the electrical systems came alive and the fuel pump started as if the key was in the run position. Warning lights on dash came alive as well. Truck fired up w/o any problems when I did turn the key. However, the key will not turn the engine off. Disconnecting battery cable will not kill truck. Had to pop clutch in gear to kill engine. When I try to turn the key off with the engine running the voltmeter will drop to zero and all the dash warning lights will come back on but the engine will not die.
Ran diagnostic test on ignition switch and it passed the test. Replaced it anyway along with the key lock cylinder as it was already hosed. Issue remains. I've looked at all of the fuzes in the Power Distribution box as well as inside the cab. I've also swapped some of the relays around in the Distro box. I've cleaned all the grounds I could find as well. Battery is checking at 12.8V but I didn't put it under load.
Numerous Google searches turned up nothing. Some suggestions would be appreciated. Currently sitting with the negative off the battery or it will run down again.
Thanks...
Thanks...
