Jsommers
Ok so ive been haveing some issues with my truck lately and i was hoping you guys could help me diagnose whats wrong with it.
First off when i first go out in he morning it will crank over for a little bit then fire. Then when you turn the key it starts right up.
Then it will act fine and drive great until i put it to the floor. When i do that it bogs down and and has no power until you lift your foot to about 3/4 throttle and and it acts fine until ou floor it again and it will bog.
Then if you park the truck and shut it off it will start just fine.
Then every once in a while about every 3rd time i go to drive it it will sit and fire but not start and sometimes when i play with the throttle it will sit and stumble for a bit until you get it up into high rpms and it will start to run fine.
Sometimes it just wont start it will fire and stumble for a second and then die again.
