96 fazda leveling questions
kman
IN
2000
so i have a 96 fazda is has the 3.0 and it has stock springs on the front i done the washer lift and got about an inch maybe if i get the two in spacer for them to do you think that i will be able to get it aligned without buying new cambers?
just get some more washers..... a 1.5" stack of washers will = 2" of lift....
don't bother with the spacers.....
l8r, John
i dont have enough space for anymore but like two washers unless there is a way to put a longer bolt in
well then put the extra 2 washers. should get you about another 1/2". thats the cheapest way. you could always get leveling coils and alignment shims if you have to
I have the 3.0 and just put 2 inch spacers in with 31's and mine was alignable. It was close i guess but they were able to get it
Oh and mine is a 97 and i do not have washers but i did not need to buy aftermarket shims. Yours i think would be close with washers too
you can get "stud extenders" on ebay. Once you get more than about 2" of spacer in there you'll run out of ability to align it.
