lupinajs
- Feb 25, 2014
- Automatic
Hey guys I have a 96 b2300 2wd that needs to pass emissions by January. The test center said they cannot get a reading from the truck. I have never reset codes/unplugged battery. The mechanic suggested a new thermostat is very common for this type of truck and issue. I have been looking at other posts and say that the cigarette lighter fuse is linked to the obd however my fuse is fine and in tact. However the cigarette lighter is pushed into the dash since I've owned the truck and do not know if it works. The mechanic quoted me $110 to diagnose and tell what's wrong. Or he said for $125 he will do the thermostat. Do you guys think the thermostat is a viable option to try first or are there more cheaper / logical approaches? I can attach a picture of the test results later today if that will help.
Overall result - readiness abort
1122 RPM
176 engine temp
Connector status - pass
MIL engine off - pass
MIL commanded on - no
0 connector voltage
Communication status - pass
Catalyst - not ready
Comprehensive component - ready
EGR system - not ready
Fuel system - ready
Misfire - ready
Oxygen sensor - not ready
Oxygen sensor heated - not ready
Not supported - air condition system, evaporative system, heated catalyst, secondary air system.
1122 RPM
176 engine temp
0 connector voltage
Fuel system - ready
Misfire - ready
