Doom's Day Custom
I have a miss fire in my 96 ranger with a 4.0l v6 in cylinder #6... I was driving yesterday and the truck started missing and as i drove for a while it got progressively worse until it acted like it lost #6 cylinder and it does this all through the rpm range.. My truck is going through coolant but i did a compression test and with all cylinders all with in range of the book specs and i am still leaking coolant some where but it not showing on the motor any where or inside the cahbeplaced the coil and the spark plug wires which are like a month old and the spark plugs are a couple months old and the crank position sensor is like a month old.... I pulled the #6 spark plug and the spark plug was wet and the spark plug that are in the truck are the stock ones ....I have lost my mind trying to figure it out but with no problem solved ,PLEASE HELP!!!!
