- Sep 24, 2007
- Age
- 39
- Long Beach, CA
- Manual
The IHI turbo off of the tbirds are crap. They will explode at anything over 12psi. You would be better off look up some nissan sr20 or ca18 turbos. They would be perfect if you ran two of them. http://en.wikipedia.org/wiki/SR20DET garret t25 turbo, there are also a few that are a bit smaller you can get these for dirt cheap on ebay. Use a 2.5" exhaust pipe coming off of each turbo. The bad thing about two turbos is that you have to buy 2 of everything, oil lines, wastegates, vacum line. If you are set on two turbos use two t3 .60/60 turbos off of the mustang svt. For a single turbo use something like this http://www.nipponpower.com/product.phtml?p=823
Hmmm, ran 17-18 normally and spiked to 21 a couple times when I ran an IHI. It's still a very intact unit.
