bobdog301
i am stumped, i have a 95 ranger 2.3 that cracked the #3 cylinder i pulled it out (2nd time) put in a 97 2.3 everything bolted up ok all sensors fit, my problem is when i go to start it she will run for about 1-2 sec then shut off(clean no buck,miss,backfire,etc.)so i pulled codes 0340 keeps commin up even after i replaced it also checked it.5v and resistance is ok. also replaced crank. also checked iac also checked timing. if i give it 1/2 to full throtle it will want to run but with backfire in t/b also will flucuate i have checked vaccum seems ok switched intakes to the old ones still nothin any of you been here before is the comp realizing old values ? i am stumped use to rebuild old muscle cars but with sensors i throw out the old gas/air /spark therories any help would be great ...thanks Bob
add : pulled plugs and they are black toooo much gas any ideas??????
