If I were personally moving to a mountain state to live I'd put the '95 heads on my 93 engine.
But as I told you in the PM, "porting" is most beneficial to an engine that revs.
the 4.0OHV CAN'T rev (dynamic balance issues)
If you were to build a completely custom engine around an engine with
an 8-bolt crank you can make it rev, but that becomes a purely custom proposition because the factory ppistons for the "lightweight" rotating assembly were semi-famous for skirt slap.
I think it best to use a stock '93-94 short block, preferably on 1993 engine
management. Not a 1994, or a Cali '93, IMO SEFI is overrated because of
the propensity for the synchronizers to fail in service.
It has been my longstanding position that parts you don't install cannot
break and leave you stuck alongside the road.
THE thing to do to "wake up" a 4.0OHV is put a set of Borla
or JBA headers on it.
Granted my first experience with my ranger at high altitude was when
I had JUST installed my 4.0 engine and TOWED my ranger to wyoming
(it was my "Lifeboat" and my trip home) with ~100 miles on the new
engine install.
My ranger literally aquired 1900 of it's first 2000miles bolted to the
back of an F-250 via a towbar.
and even though I had a full load of fuel (this has special meaning on my truck)
onboard and I was at high altitude even climbing the hill getting onto I-25 North
out of casper heading towards Barr Nunn, there was no mistaking that this truck
was faster than it had ever been with a 2.9 and my only basis of comparison
was running that 2.9 at the ~500-1000ft elevation at home.
How strong the 4.0 is really became noticeable climbing up to the overlook
just on the north side of casper mountain on the road up to the Hogodon
ski slopes. Climbing that hill and going from 6000-10,000 ft with a full collection
of spare parts and ~600lb of fuel and the A/C running full blast in the 106degree
heat was eye opening.
the 2.9 has to be spun to 2200-2400 before you start to feel it get into
the torque.
a 3.0 feels "worthless and weak" to most people because they really never
go looking up at 2900-3400rpm where it is found and it isn't real distinct
when you find it.
The 4.0OHV is torque RIGHT F'IN NOW! from 1250rpm on up.
Anything a 4.0 powered truck won't do is probably due to gears that
are too tall.
Dave on your Explorer I have one thing to add: 3.73 gears.
Your '91 explorer probably has 3.27's or 3.55's, change them out.
And Dave, while I did reply to your PM's I posted in this topic before
I had about a dozen replies vanish and I had to repost some of them.
AD
