'95 4wd Ranger new parking brake cables too tight
Pittsburgh
PA - USA
Vehicle
Drive
2"
Hello all, I feel like I'm going crazy. I bought this '95 a week and a half ago because it was basically free of rust, which is unheard of in W. PA.
That's about all it has going for it though, it's been manhandled for sure. Among the many issues it has was a disconnected parking brake system with rotted cables. The 4R44E won't go into park (whole other story) so I wanted to get the e-brake functional while I get this thing back up and running.
My local NAPA had the rear left and right in stock and I confirmed they were for a 10" brake truck, like mine. I got everything apart and started mounting up the new cables until I went to join them to the front cable. I confirmed the parking brake pedal was all the way up and released and yet I could not get anywhere near close to hooking the front cable to the rear cables. The only way I was able to get them joined was by blowing apart all the drum brake hardware. But now I can't seat the front cable in its bracket and the rear springs on both cable are almost fully compressed. Pictures below for reference:
Any ideas? Anyone had this problem before? It's almost like there's too much spring on each cable. I put them side by side with the old ones that came off and everything basically looked the same.
Hmm. I know that I ran into a problem on my one 00 Ranger where there was apparently a standard and HD option for the cables. Problem is, most parts stores only list and stock the standard option and not the slightly longer HD option. Not sure if that applies for the pre 98 trucks though. I also know that on my 00 trucks there’s a way to re-set the ratcheting e-brake pedal assembly and that there are different intermediate cables but again, not sure how much of that applies to the 93-97 trucks.
I just did this like a week ago. There's 6"+ of extra slack in the front cable beyond just having the brake off.
Take the trim off the ebrake mechanism and shine a light in from the front. There's a vaguely L-shaped piece of metal with a torsion spring on it, that allows a cog with tiny teeth to ratchet one way (taking up cable) but not the other (releasing it).
Stick a punch or a drill bit or a hex-key or whatever in there and bend the keeper away (I think it's down) to free the mechanism while you pull the front cable hard with your other hand. It'll pull back far enough to reach the rear cables.
If you can't get it by tomorrow night, I can take a picture of what I'm talking about.
^That's the reset lil_Blue_Ford was talking about. It's even on my '88. Thought it might have a pedal assembly from a newer truck...
The pedal and ratchet release mechanism changes slightly between some years, including '94/'95.
I got all turned around because the '95 manual still references how it looked in '94.
So you all were dead on with the problem being in the pedal assembly. Somehow, and I never would have guessed this could happen, the cable came out of the little guide fingers that keep the cable traveling on the outside circumference of that wheel which wedged the cable in between the clockspring and the housing. Basically even though the pedal was up it was as if the brake was applied.
I took the pedal down, unstuck the cable, routed it properly, and wouldn't you know I have excellent, working brakes. Thanks again!
Did you have to take the pedal assembly out to do this?
Negative. Just the kick panel off the top of it. Depending on exactly what the cable is doing, unbolting the assy could make it easier.
I swapped axles, going from 9 inch drums to 10 inch. New rear cables. I pulled out all the slack I could from the front cable and vice gripped it to the frame. I got the cables on the equalizer but the end with the spring is too tight to reach the shoe. I found a video of someone cutting the spring shorter so it would fit, but I'm not sure I want to go that route.
