Cyb3rst0rm
I bought a 1995 Ranger with 259k miles on it and a 4.0 with the 4 speed/OD automatic. It's running pretty good power wise as far as I can tell but it's burning oil as well as leaking it. Paid $700 for the truck.
I was told the truck had sat for 6 months so let's take that into consideration.
The symptoms so far are:
Aside from the heads or gaskets, what could this be? I'm thinking valves or maybe the EGR seeing as how the exhaust smoke and engine bay smoke stop or diminish greatly once I'm moving.
I don't think the rear main seal can cause it to burn oil can it?
If it's the head's I'm just going to leave it and hope I get to 300k before the engine detonates. I haven't changed the oil yet as I'm running stop leak through the motor but I usually run Valvoline High Milage Synthetic on a 3000 mile interval.
I figure if I change my plugs every 10k or so I should be good as long as it's just oil, since the main effect of that if I remember my engines 101 is fouled plugs. I don't have the mechanical skills to do it myself and realistically the truck probably isn't worth the labour costs to have a professional do it seeing as how it's already fairly high milage, the transmission isn't great (it isn't out right slipping but it makes some noises that concern me), and the body has various dents and dings throughout. I just bought the stupid thing to use a work commuter anyways.
- Hard, rough starts (3-5 seconds of cranking, pretty violent when it finally catches) but has never failed to start.
- Grey smoke out the exhaust, leaking water and at various point had oil pooling at the end of the pipe.
- Intermittent smoke in engine bay. Only when it's been sitting since started, if I drive it a few miles then park and pull the hood it doesn't do it. The smokes pretty minor, enough I can't really tell what color it is.
- Rattling noise from engine (I've had two people tell me it doesn't sound like the timing chain and this isn't an SOHC anyways)
- Leaking oil where the transmission meets the motor.
