bubba cakes
- Dec 5, 2008
Without going into the engine, i'm considering the following improvements to my little truck, to make it all it can be.
1. Disable the EGR valve, thus eliminating exhaust gases from combustion air.
2. Remove the catalytic converter, replace with straight pipe.
3. Install an electric fan to eliminate drag on the engine.
4. Install a set of underdrive pulleys, to further diminish engine drag.
5. Remove the a/c compressor, for even less engine drag.
6. Install a higher numerical ratio rear end, with LSD.
7. Do some DIY intake porting.
8. Remove the air intake muffler and baffle.
9. Install a Jet ECU upgrade kit.
10. Install a hotter thermostat if more research indicates that will help.
11. Install a throttle body spacer from JET.
12. Install a booster rocket in the spare tire space.
just kidding about #12.
so if each of those improvements increases my hp and economy by a few percent, i ought to go from 100hp to 125 maybe, huh? Economy ought to go from 26mpg to 35, right? just kidding again. i have no idea, but it ought to be a big improvement, i would think.
am i wasting my time for just every day puttering around town?
