2.3L ('83-'97) 95 2.3L engine sluggish when slow, then runs normal at higher rpms
Pooler
GA - USA
Vehicle
Drive
2WD
2.3L
Hi everyone! I have a 95 ranger 4 cylinder xlt rwd. It has close to 300,000 miles on it. The engine is sluggish at low rpms and struggles to move the truck, when I am about halfway through a gear(manual/stickshift) the engine starts to run like normal. When I shift it is sluggish again. When it almost gets back to producing power the engines surges a little between sluggish and full power(hope that makes sense). I have also had the truck cut off on me when braking hard and in neutral. It also backfires if I switch gears and stomp on the gas. I have changed the fuel filter, recently did plugs and wires, and replaced the 2 coil packs. Any ideas? TIA!
I would get a compression tester, warm the engine up, take all the sparkplugs out, pull the fuel pump relay and tie the throttle wide open. Then do a compression check. Let's see how tired this engine is. With 300,000 it's going to definitely have some wear, I just wonder how bad it is.
I'm with Franklin...
'95 should be OBD II so I would get something that will read things like fuel trim and MAF sensor output, at idle it should be close to 1 on the fuel trim both short and long term and the MAF reading should be in the neighborhood of 2.3g/s
There's either a compression issue, bad vacuum leak probably intake manifold gasket, or bad oxygen sensor are my main guesses, if hard part it could be some recessed valves as these are known for it and makes them run weird...
