auto117584
- Oct 1, 2009
Can you help me identify these parts? I will tell you where to find them in your 95 2.3L truck. Open the hood, look along the driver's side of the engine bay, right along the edge where the hood shuts. Under that ledge there's a huge trunk of wires, neatly wrapped, that travels from the front driver's corner of the truck, back toward the driver. It passes to the outside of the battery, between the battery and the side of the truck. Got it? Right after this trunk of wires passes the battery, headed toward the rear of the truck now, there's a branch that comes out of it. the branch heads straight toward the engine. the branch itself branches into 3 sub-branches, all of which have electrical connectors at the ends. two of those connectors plug into connectors that are on this "thing" that I'm holding in the image above. the other connector may or may not plug into something at the bottom of the timing belt area. Do you recognize this stuff? Look at your branch, and the three sub-branches. Do they follow the wheel well, go down? Does one of the vacuum hoses hook into some kind of cannister under the headlight? Into a fitting under the cannister? Where does the other vacuum hose go, the one in my picture? Under the intake manifold? I think I have a loose fitting there, i mean, not occupied. Needs a hose on it.
In the picture, the light-colored thing next to my fingers is a cable tie-down thing. it is attached to the hose thing in the picture and it also has a thing so it can be taped to another bundle of wires or hoses, plus one it has one of those things that get forced through a hole to become attached. you can see what i'm talking about here:
Thanks for the help!
