- Apr 10, 2011
I have a 95 2.3 5 speed extended cab 2wd Ranger that has a starting issue...
If it sets more than a few hours it refuses to start. It will crank like hell but never actually start and run unless you crank it alot (Imagine an old diesel on a cold morning with no glow plugs or a block heater) and hold the throttle wide open and then it will just chug forever before running smoothly. You spin the engine over with the starter for a long period and it wants to start but cant. Once it starts its ok and you can turn it on and off all day long as long as it dosen't set more than a few hours. Sometimes it will not start at all and we will have to pull start it in 5th gear until it finally starts running and you have to down shift to 4th and let it pull it till it is running good and then you can drive it. And when I say pull start it I mean pull it in 5th gear, not get it up to speed and dump the clutch like normal, I mean put it in 5th gear and drag it behind my Explorer or F150 until it actually starts. It does no good to cycle the fuel pump multiple times either. It starts the same wether you do it once or ten times...
New fuel filter...
35 PSI fuel pressure at the rail when you first roll the key in the morning...
Spark is fine cause it actually starts fine after it is warm...
Could it be the fuel pressure regulator?
New fuel filter...
