dpfurby
- Jun 1, 2013
- Automatic
On highway yesterday drove about 50 miles at 65 with no problems. On return trip going along fine then engine started missing and RPM dropped to less than 2000 -- with accelerator floored. No power. Pulled over waited and barely limped it home.
It has 218000 miles.
I replaced within the past 3 weeks--
plugs
plug wires
fuel filter
throttle body position sensor
coil pack
engine coolant temperature sensor
cleaned mass air flow sensor per the book
cleaned the idle air control
replaced the intake gasket when I replaced the valve cover gaskets
cleaned the throttle body
checked all vaacuum hoses
does not burn oil
not overheating
oil shows no sign of coolant
Catalytic converter clogged???
Any help appreciated!!!!
plugs
plug wires
fuel filter
coil pack
does not burn oil
not overheating
