Keekee
Hello all! This is my first post, let alone on a website like this. Did quite a bit of research over the last several months to build a diesel ranger. What I found was
-4BT engines were to heavy
-Perkins are F*!@# expensive
-Izuzu was hit or miss for cost efficiancy
-Toyota diesel...HA!
-Detroit diesels were mostly in Canada and east coast
SO! what I came up with was a swap to a 1.9L VW TDI and after some looking and finding yet again, pants needed pulling down to get one of these engines atop an obscene amount of wiring. After cruising the CL ads, came across a fella with a VW NA 1.6L (he thought it was a 1.9) sitting in the back of his shop for the better part of the last 20+ years... I was skepticle of the $150 price tag that included a complete motor and tranny. However, I took the gamble and turned to be an EPIC WIN
. Just some stiffness from sitting but nothing blown, just one stuck cyl where a little rust has formed from an occasional rat home.
After looking at power levels and through hours of the nay-sayers I did find some rays of hope and FINALLY found some dyno specs of a turbo conversion that did NOT dump 20+lbs of boost and obscene mods... this motor with the 5 speed and gearing I have WILL work for what I need it for, just wont burn all 4 tires and I plan to keep my little 31s and just level her out.
Here is where I am now: motor has been torn down and working on the one stuck cyl. Got the head ready to blast and will be doing a port/ polish job. I am blessed with a friend who has a CNC machine if I need, but I will most likely build my adaptor out of plexi-glass and transfer to an aluminum plate.
I am not going to modify the hell out of this thing, I plan to replace rings, seals, ect... the essentials. I will be adding a turno, relocating the oil pump+oil cooler and POSSIBLY some home made oil skirts, intake, ect... I MAY convert to a electronic water pump though... anyone have experience on these?
