BoDean
- Mar 26, 2010
I have a manual '94 Ranger 2.3 liter 2x4 that was given to me by a guy at church. The transmission was low on gear oil, and the gears were beginning to whine. I knew that I needed to top up on the lube, but I didn't. Shame on me. The transmission got really hot one day, and the clutch wouldn't even disengage right, I pulled over and felt the tranny, it was scalding hot. I took it to a nearby Sears, and they topped it up with some 80/90 weight. Now I hear that you're supposed to put Dex/Merc auto tranny fluid into the manual tranny, as 80/90 can be too thick. The truck drove fine for a while, but then it got stuck in fourth gear. I removed the shifter, and the access panel in the floorboard, and hack-sawed about six inches of floorboard to remove the top of the tranny, or the shifter-assembly. The forks were in the right place. I verified this several times, even used a tape measure to make sure they were right. Come to find out, fourth gear is bound to the shaft. even with the selector rings in the neutral positions, the truck moves in fourth gear when I release the clutch and give it gas. I wiggled all the gears, every gear has a little bit of movement, except fourth, which is totally solid. The gear itself has actually moved forward about an eight inch on the shaft, and the gear is a little ate up. Is there any way to unbind the gear without taking the tranny apart? I think it's time for a new tranny, but I would like to fix this one if possible. Sorry for the super long post, this being my first post and all. BTW, I would like to take this chance to personally welcome myself to The Ranger Station, and to Ranger ownership in general.
