Tractor Dan
Here are the specs
94 Ranger
3.0L
Rear wheel drive
Manual Trans
The original engine went bad in it. Blown crankshaft. My mechanic dropped a yard engine in. Not sure what year the donor vehicle was but the IAC had a date sticker with 1990 on it so leads me to believe it was a 91 or 92 motor. The old engine i believe had EGR and the 91 or 92 motor didn't. I base this off the fact that my mechanic swapped the upper intake off the blown engine over and plugged the hole where the EGR valve would bolt up.
When i put the clutch in it revs up. Not sure what the rpm is as i don't have a tach. When it does this it's only if the clutch pedal is depressed and as soon as i shift to the next gear and let the clutch out it goes back to a normal idle. It also does this if i leave the clutch pressed in and try to hit the brakes to slow down or take it out of gear and try to slow down using the brakes. So i can't figure out what's going on with it. I did get a check engine light tonight and if i was reading the flashes of light correctly on the dash board using the method to retrieve codes i was getting codes 31,32,33. I'm not sure if i was reading them correctly though.
So what i'm wondering is could this be a computer issue where the computer is having issues since it's not seeing any EGR on board what so ever? I know OBD1 is not as sophisticated as OBD2 but i would assume that if an ECU was programmed to see a component and it didn't especially something like EGR it would have issues? So i'm trying to decide if i should find an ECU for a 91 or 92 motor once i determine which it is that is set up for my spec and no egr and try that? The computer systems are still new to me. I just finished one class at school on them that was more or less an introduction to it. The next class gets deep into the theory and logic behind them and whatnot.
94 Ranger
3.0L
Rear wheel drive
Manual Trans
