94 Ranger left indicator light problems
therh
I have a 4.0 2WD Ford Ranger and have encountered an odd problem.
All was fine as I was coming home from the grocery store. For whatever reason my left indicator signal is not working properly. This is with or without the main lights on or off.
When I go to use the left turn signal this is what happens:
Front Indicator Illuminates normally, but stays on.
The the left turn signal dash light also stays on.
The rear light does not come on, at all.
I looked at the fuse that is used for these the lights and it is not burned out or even black.
Does anyone know what could be causing this? And how to fix this?
RH
