thcscubajohn
- Nov 23, 2014
- Antarctica
- 4.0 V6
- Total Lift
- 4"
- Tire Size
- 31x10.50r15
- My credo
- Smog is for pussies.
So, I thought this belonged here;
I'm "halfway" through building my 4.0.
Here's the parts list:
Brand new stock con rods
ARP rod bolts
12.9 class head bolts
Reman 98tm heads
stock intake
Delta 937 cam
Comp cams sprimgs and retainers
KB flat top hypereutectic pistons .030
Hastings plasma moly rings
Double roll timing chain
Melling high volume oil pump
TwEECer RT fitted PCM
Ebay shorty headers
24lb Bosch injectors
45,000V coil pack
40ohm/ft plug wires
Motorcraft platinum plugs
Brand new ford lifters
All new sensors
ARP rod bolts
Reman 98tm heads
stock intake
Delta 937 cam
Ebay shorty headers
45,000V coil pack
40ohm/ft plug wires
All new sensors
