jinx44
- Jul 12, 2012
- Automatic
I just bought a '94 Ford Ranger, 2.3L, 5 speed, 2wd with 199,000 miles. It has a slight miss/hesitation at cruising speeds and lower throttle position.
KOER scan shows code 411---Cannot control rpm during KOER low RPM check.
The idle speed was 1180rpm, TPS at .98v, IAC duty cycle 0.0, MAF around 1.1v.
The TPS is not slotted for adjustment.
If I turn the idle screw down, I can get the IAC to command 10-15% duty cycle and it will idle at 720rpm. However, my TPS voltage is down to .83 and it still has the miss.
I checked for vacuum leaks and could not find any. Since intake gaskets are cheap, I put a new set on, checked the intakes for any cracks, and went over the vacuum hoses as I went back together with it. The only vac hoses are for FPR, EGR, and A/C controls. Capping them one at time did not change anything. Since putting the gaskets in, I have sprayed 3/4 of a can of ether around everything and still no sign of leaks. I also replaced the PCV valve to fix vacuum on the crankcase, and replaced the ECT with the updated Ford kit since I had the water drained to remove the intake. While I was there, I replaced the spark plugs and wires with the recommend Motorcraft parts. The old plugs had 15k miles on them, and all looked fine. No sign of coolant, oil, or rich/lean on any cylinder.
I have access to a wrecked truck for parts, so yesterday I tried swapping the TB. With the TB and TPS from the other truck, TPS is at .94v, idle still at 1180, and IAC still commanded 0.0.
This morning I swapped the IAC from the wrecked truck in case it wasn't closing properly. Neither IAC closes completely, so I am guessing that is how they are from the factory. But even with the new IAC, everything is the same.
I am thinking about slotting the TPS so I can turn the throttle blade down and still keep .98-.99v. However, there is obviously an issue somewhere and I would rather fix that issue than bandaid it.
I pulled the timing cover yesterday to check to make sure the cam timing is correct (previous owner put a new belt on it 15k ago). Crank and cam are lined up correctly. I can't find a timing mark on the cover for the oil pump gear though. I am not sure that it matters on a '94 since there is no distributor or cam position sensor.
When I was on the way home with this truck a couple weeks ago, I had to make a stop at the store. When I went back out to leave, it wouldn't start. It took a few tries, then it fired up like nothing was wrong. When I got home, I ran the KOEO codes and it showed a PIP/CKS erratic signal code. I have put 500 miles on it since without a no start issue or with that code coming back.
I am considering replacing the CKS while I have the timing cover and all off. I just hate to keep throwing parts at it though.
Any ideas?
Any ideas?
