94 Mazda b4000 transmission problems
b_easy20
Okay so this is my first I'm on any forum and just can't seem to figure out what's wrong with my tranny, so when I try and go into first or second when the trucks running it's almost impossible to get it to go unless the trucks off and when I start the truck in 1st it trys to go forward sometimes and all the gears grind thank you for your time!!
Sent from my SM-G900P using Tapatalk
Check in this order
1. Air in the hydraulic clutch system
2. Bad Master cylinder
3. Bad slave cylinder
4. Bad clutch
