B3000SE
Hey Everyone I have a 94 B3000 SE Extended Cab Auto Trans 2wd,I Just Replaced a sticky Thermostat because the truck took forever to warm up in the morning, I also Flushed the radiator,well after doing this it still takes awhile to warm up from sitting all day or night and the temp gauge moves up and down quite a bit and sometimes will go up 10 degrees past half on the temp gauge when its 45 degrees outside.I Bought a Quality($10) Thermostat with a Burping Valve on it,I have had no check engine lights and it runs rough when cold between 1000-2000RPM's (It Misses) ,This is new to me I haven't owned the truck very long and don't know much about Fords.Is this typical for this truck with age or do I have a Big Problem happening ? I would appreciate any help if I can Prolong or prevent a major repair.....
Every Ignition Part Has been Replaced
