Jonno
- Feb 4, 2008
Hi all,
I haven't seen this problem described on the forum archive. The other day I happened to notice my temperature gauge was almost red lined. I put the heater to max and it dropped a bit but was still above the 'L' in NORMAL. A few hours later I put some more coolant in (the reserve was low) and started it up but within 3-4 minutes the temp was starting to rise abnormally again.
I shut it down and noticed a drip coming from what I think is a flushing kit adaptor that was put on. I tightened it and figure the coupling may have gotten a little loose with the big over heat earlier. When I tightened it, I got a face full of coolant so the system seems to have pressure.
Here's what I have checked (not with any fancy tools):
1) System seems to have good pressure
2) System has coolant
3) Rad cap fits snugly
4) No oil in coolant
5) Doesn't look like water in oil
6) Top water hose on rad is very hot so I think that means the thermostat is working, ya?
7) Fan works and is in good shape
8) Rad fins are not blocked and seem in good shape
I guess that's it. I haven't found anything on the internet or repair manuals that explain how the temperature can get so hot so fast and stay there. Please correct me if I'm wrong, but if the top rad hose is hot, the thermostat is fine, correct? There's no funny sound as if the water pump is gone but could that be the problem too?
