94 explore wont go into gear
MSilver
My A4LD failed a while ago, I bought one from a guy he said it worked when it was pulled out. i finally finished installing it , filled it with fluid, started the truck let it run for a while. it didn't seem like it took near as much fluid as it should (3 an half ish quarts). Put it in reverse, rpms changed, let off brakes... nothing give it gas slowly let it rev to around 2,500, still nothing. cycled threw all the gears none moved it. I kept checking the fluid never needed more, let it run for 20 minute. pulled cooler lines at the radiator and they were dry. next i was going to try to take off the line on the trans to see if there is anything there.
Any ideas, tips, suggestions?
